Another concept I came up with, it still opens the same as the stock tailgate, but would still clear the factory bumper. Loading and unloading of the spare would be fairly easy as well.
I like it.
looks good to me as well. What size tire is this gonna hold?
Also having to lift that up with a big tire ain't all that easy I bet...quote]
I'm really not bothered by the weight of the tire (maybe 120Lbs total), but the bulkiness of not being able to get my arms around it. Any design that allows me to lift the tire with the help of some kind of tube or handle, and a fixed pivot point so that it isn't shifting all around makes it a lot easier to deal with.
Also it not being a solid gate allows rain into the bed. Your design would keep intruders out atleast.
ANything bigger than a stock tire and your gonna need some assist struts on that thing.
Looks nice though!
You have to realize you are using a lever to provide mechanical advantage when you lift the gate. So a 120# tire and wheel will now only take 60# of force to lift with a 2:1 lever (if the weight of the tire is in the center of the gate). I would probably add a handle that gives more leverage than that depending on how hard it is to lift.
