- Joined
- Aug 23, 2017
- Posts
- 7
- Reaction score
- 0
Does anyone know anything about the rod that goes into the channel on the tailgate to help assist in closing it? Mine was in three pieces and fell out and now the tailgate is extremely difficult to close.
Where do I purchase one? So far I've been unable to locate one.I assume you mean on a square blazer or suburban. It is a torsion spring attached at each end. It helps lift the heavy tailgate with the windows in them. The pickups do not have them. Just get a replacement and bolt one back in. Extra set of hands helps.
man if you had one that would be great. Nothing online , junkyards don't have tailgates from 84-87 Blazers.I might have one, I did a truck tailgate swap on my blazer. Let me check the parts shed. Not sure if they are available or if it's a junkyard part.
Ok well that makes me a bit smarter but still without them.There's a right and a left not just one.
Never seen them other than used.
81621I have a pair, let me see what size box they fit in. They are off a 1990, I have no idea if there are multiple styles. The guys on here will probably chime in. What's your zip code?
Ok that would be great! Just gotta buy some! The existing parts look to be the thickness of say a golf club shaft?I can look it up later but I'm 99.9 % sure they are the same 73-87
Great ! Thank you so much. We can do a private email or similar for payment.
