COWBOYK5BLZR
ok guys ...I NEED HELP PLEASE !!..i am trying to rebuild my tailgate with electric window and i recieved all new internal parts from LMC...
Problem #1....when installing drivers side window channel (metal part in tailgate with the felt that glass slides down in ) no matter where or how I route the damn wires to electric motor they get in way of the channel piece
...for starters can anyone tell me if that little plastic wire clip goes in thru mounting hole clip in front or clip in rear ??
Problem #2...do I mount glass in bottom sash ,then install glass and sash in tailgate before or after installing weatherstripping(inner and outer glass seals)...and will it even fit thru with inner and outer seal installed ?? ?
or do i intall glass then try to slide glass in bottom window sash while in tailgate ??
...or would I install inner and outer window seals last thing after tailgate is all complete with glass installed ??
THANK YOU SO MUCH FOR ANY HELP OR ADVICE AS I AM ABOUT TO THROW A HAMMER ACROSS MY GARAGE
...for starters can anyone tell me if that little plastic wire clip goes in thru mounting hole clip in front or clip in rear ??Problem #2...do I mount glass in bottom sash ,then install glass and sash in tailgate before or after installing weatherstripping(inner and outer glass seals)...and will it even fit thru with inner and outer seal installed ?? ?
