The day I dreaded since I Decided to refurbish the K5 came. I had to replace the tailgate support FIRST before the donor Quarter Panels are installed. The existing TG support was horribly corroded (as many are).
There really wasn't much out there for replacing this support. Found a YouTube video where the TG Support was cut into two pieces then installed. I really didn't want to do that and since the Qtr Panels are being removed I went with cutting out the old one. The upright supports had some tight inside corners which created potential problems with my angle grinder/cutter. Went with cutting the external body skin around the taillights first. I then cut most of the corners areas from outside the vehicle. Kept those parts because you never know when you'll need them.
The body mount bolts were shot. Only one had a nut on the bolt. Both were swollen by corrosion. Had to cut off the bolt heads and get out Big Nasty to punch the bolts downward. After a good fight, the bolts lost and Big Nasty was awarded another gold medal. So far Big Nasty is undefeated. Big Nasty is the shit!!!! (Astro 4980 air hammer).
Cut the bed panel and after a few tugs the old TG support came out. I first placed a series of wood boards between the frame and underside of the bed to support the bed once the TG support was removed. I got some minor sagging but I can't tell if it actually sagged or if the old support had issues to begin with.
New TG support went in with some minimal tweeking. It is just sitting there now. I haven't bolted it down yet. Everything seems to be fine....
Any comments, thoughts or suggestions?
