Tailgate Window motor won't go down
pblaze725
build bash rebuild
San Carlos, Ca
So I did this:
For you noobs.:D
little trick.....assuming the back key works... put the key in and turn to lower the window. while you are turning the key...push in and out hard on the tailgate.. I have to do this to mine sometimes.. dont know if it has to do with ground or safety switch
The back key does not work for me. I don't have the key for the tumbler.
I accidentally locked the tailgate when i was working on it. :doah:So I got the window down, shut the tailgate,and then couldn't get it open again! :haha:
I had to take the bolts out of the latch mechanism to get it back open. Then went back inside the hatch and removed the locking bar. :whistle:
The window motor is about to die. That's easy to fix.
