I've got an 1988 k5 and is in search of the regulator transmission with no luck. I work for a gm dealership and that part has been discontunied, and classiccars.com, lmc.com doesn't have them.. Any help would be thankful.
Used only. Find one at a junkyard or online. May check the classified section here but that may be "members only" accessible.
I have one but this is not the for sale section. I'm changing mine over to a manual operated window. You should look into doing the same as the power ones are problematic, being a GM tech you probably know that already.
