and burn it into the ground... i really am about to take all my friends advice and just put a carb on it..
So over the last month my 1987 K5 w/ a 350 thats TBI, loves to just completely die when i sit in traffic for about 10minutes.it will be idleing fine, then i hear it studder a lil and it just shuts off. It first started waiting in traffic one day, died, i pulled over, w/ the lil momentum i had and sat for about 20minutes because it wouldnt start. Started up again i had a valve tick and pulled into a parking lot. so i let it sit for another 10mins.. drive then park it. Come back 2hours later, drive it home in no traffic just fine, runs smooth, no tick. After it dies like this i have to wait about 20-30minutes before the engine will start again. Happened again tonight and i've about had it with this junk. Someone PLEASE give me any idea what could cause this?
UPDATES!!!!
OK so the above problem is fixed.... but now a new problem developed. I am driving a long, truck runs smooth, i start to go thru a turn and not using the gas. The truck studders and dies for 1second so i floor it coming outta the turn to try to save the engine from dieing completely and it kicks back on and drives normally. Only does this on turns and not every turn. Second problem is the day after the stalling around turns started when i have the truck parked in a parking spot.. i put it in reverse it stalls out and dies. I have even kept the rpms up when putting it in reverse and still does it. Can someone give me an idea wtf could be wrong??
UPDATES!!!!
