Taking leaves out of a 12 inch lift?
MOBK5
Mobile, AL
Ive got a lineup on a 12 inch lift kit, but theres a problem. I only want 6-8 inches. The guy selling it to me is a mechanic and tells me I can take leaves out, replace them with leaves with less arch and it will take the lift down a few inches. I dont doubt what hes saying at all, Im just curious if any of you guys have done it. I like the idea of rebuilding them with less springs and getting more flex, but I dont know how my shakle angle will be and all that jazz.
Shortened: Can I mix and match leaves to make a 12 inch spring to a 6 or 8 inch spring easily?
Lots of ppl do this wiht 6 or 4" springs, so it could work on 12" ones.
Personally, i wouldnt' do it....you shoudl be able to find some 6" used ones pretty easily instead. If you take leaves out and essentially lower the spring rate, the spring will sit lower and end up being longer eye to eye, making for wierd shackle angles. Yes, this happens when you do it ot a 6" spring, but it wouldnt' be as drastic.
Anyways, thats just my personal 0.02, lets see what others say....
The main leaf on those 12" front springs is extremely arched, even if you did remove a few leaves I would think it would cause undue stress to the main leaf of those front springs.
The 12" lift kit comes with 8" rear springs and 4" blocks, so you could just ditch the blocks in the rear.
I took the lower two springs out of my 12" pack, and tho it wasnt' on the road, it flexed alot better, lowered it 4-5" (guessing), and didn't really effect shackle angle too much. Try it, if it's doesn't work there are alot of people selling 6" springs.
