Taking out a driveline. Do you need to mark it and why?
chalet2506
CK5 Huge Member
Skeddadlin
Took the 2 pc driveline out of my F250 and had it rebuilt. New u-joints, new carrier bearing and balanced. Now I've got what feels like a driveline vibe between 55-70mph. I figure there's 2 possibilities.
1. The shop goofed it up, but I've used them before and they're reputable.
2. I didn't mark the driveline when I took it out to make sure it went the same way. I read now that you're supposed to put them back in the same position they came out, but I don't see why you need to?
Think I'll just trying rotating it 90 deg until either the vibe goes away or I make it a full turn. After that it'll go back to the shop.
If it's been balanced after rebuilding it shouldn't matter. Make sure you have the caps completely in the yokes, or the flanges. Make sure they're tight. It you have u-bolts for the caps, 15 inch lbs. Don't overtighten
No u-bolts, its flanged on both ends. I torqued them to "it won't go anymore" specs.
Some 2 peice shafts cant be put together "wrong" because they have a missing spline ,so it'll only slide together one way..others must be "clocked" correctly to get the phasing correct..usually the u-joint caps must be 90 degrees apart from each otherbut I recall some GM trucks being set 4 splines "off" too!...
Some trucks that use a center carrier bearing had a shim uder it,if that gets left off it'll screw up things too--some GM trucks back in the 70's needed a 1/2" thick spacer added under the bearing to eliminate a driveline shudder when it shifted into second gear...
