Tansfer case switch
manyblazers
toronto, Canada
Merry Christmas everyone. I have a 96 Yukon and it's gas mileage has been cut in half. New pump, wires cap and rotor and plugs and gas filter and air filter and still no improvment. I was wondering if the transfer case might be stuck in 4 wheel drive. Is there a switch I can test on the case? If yes any ideas where it would be. Thanks and Happy new year to all.
Your best bet is to jack the truck up on all fours and see if the front d/shaft is spinning;)
If the front axle was engaged you would feel it binding when turning and even if you were stuck in 4wd I don't know that it would cut your mileage in half. You might want to have someone look at your O2 sensors and fuel trim data with a scanner rather than throwing more parts at it.
