I need to shorten my heavy duty tie rod that is for the conventional placement for use with high steer. What size tap do I need to retap the end after I shorten it?
How much shorter do you have to go? Can you cut an inch off each side and be good? The tierod end has about 2" of thread and tube threads go in about 3" IIRC. I just had to do this, going from a D44 to D60.
