Stomis
Professional Amateur
So I'm not gonna spend $85 to have my toe aligned when I get my new tierod. Whats the proper way to adjust it with a tape measure? Where should I measure from and to etc?
Toe measurement MUST be measured at the outer most portion of the tire to be correct.
)Inside-outside doesn't matter, the tire's width should be the same unless you have tires with a variable width (and those would be some pretty funky lookin tires)
From one of my previous replies;
Put a piece of tape in the middle of the tread on both front tires (lined up with the hub). Draw a vertical line in marker on each piece of tape. Measure the distance between the two marks. Now roll the truck forward or back until the pieces of tape are on the back side of the tires. Measure the distance between the two marks. The front measurement should be 1/16-1/8" smaller than the measurement on the back (i.e. tires toed in).
Alright I know the concept of it my main concern was whether I should measure off the actual rim since its solid and not changing or the tire but I see why it has to be the tire now.
Thanks alot guys!
You want to measure off the tire. 1/8" of toe in at the wheel could be 3/8" toe in at the end of the tire.
To play devil's advocate here, couldn't you just pop the old off with the truck on the ground and adjust the new one to fit without moving the tires? That is, of course, assuming the alignment was correct before the swap (aside from the case of a bent tie rod)
