Tattons front driveshaft
rob h
frackville,pa
I have a few year old tatton driveline front driveshaft, 1350 cv with flange to fit 205/208/241 and long 10 inch slip with a 1310 at the axle end, The axle end is non greaseable, ground for maximum angle. For referance in length the Shaft is on an 8 inch lifted shortbed chevy, 26 inches puts it in the middle of the slip. Looking for 200.00. Only removing it to go to all 1410.
Pm me here or call/text 57zero-449-9910
Here is a screen shot when it was new, its hard to take one on the truck. I'll post the best I can tho. Unless I pull it and take one. Only thing changed is the boot is now red instead of purple, paint isn't pretty either but I'll clean it up..oh and dirty from the last trip....the whole trucks still a mess. Let me know, I just want to upgrade a little. Remember this is all Spicer parts n joints except the tube. Shipping might not be real cheap tho, prob 30-35.00 because of the weight but i can check on that.
Thanks Rob. I need to take a measurement to see if it will work. I'm pretty sure it will. I won't have the funds until middle of the week. I will let you know. Thanks.
Ok, just let me know. I won't be able to take it off till then anyway. It has plenty of slip for a good flexy set of springs.
