TB/wiring issues
lak2004
Durango, CO
The TB I have came off of a Van w/a 350 in it, I think it was a 1990. The wiring harness I have came off of a blazer.
The TPS sensor on the TB has a different plug than what my wiring harness has. Any suggestions?
Should I swap the TPS sensor itself or go for a different connector? Will this TB even work?
Its going onto another TBI 350 engine.
Just swap the connector, the wire colors are the same and it's just a matter of splicing the new pig tail on. The TPSs are not interchangable on the throttle body.
Thought that might be the case. Anybody got a connector that will work? I sold all the harness from this TB.
If you've got one handy, probably a good wrecking yard item, although might be a bit rare.
Napa may be able to help you out, or GM, but with the age, GM might be a longshot.
Personally I'm too cheap to pay for any of those connectors...as in the case of the temp sendors, the connectors can be more expensive than the component they connect to. :(
Yea it is the small round one instead of the flat one. Thanks for that link that is exactly what I need and cheap too.
