When I bought my 87 blazer it came with TBI #17093030. Decoded it means it came from a 1993 vehicle, Monojet (1bbl), with auto tranny? This TBI unit has 2 injectors....doesn't that mean it's 2 bbl? Or did I lose another marble!
I found a used TBI 17087101 on ebay that came off a 1987 K5 but with manual tranny. And I have been using it since then. Only now it surges because of bad bushings on the shaft so instead of rebuilding it I swapped the 1993 TBI unit back in. It runs good but the idle is a little low. Is there an adjustment for this?
What is the difference between the two? Will my 87 K5 run without any problems using the 1993 unit? Is there any adjustments I need to make. Will it make the blazer run richer or leaner?
Just want to make sure before I get too far and for some reason the ECM takes a dump because of the different TBI.
willie
willie
