Kocher93
So after my 14 bolt swap is done (which I still am spending way to much money on) I am going to be building up my 1989 TBI 350.
So far I have headers with a 2.5 Y pipe to a cat, muffler and a single exit out the side of the body (like a trophy truck).
I have a couple things I want to do/ buy for a mild build.
So this is one of them:http://www.summitracing.com/parts/CCA-K12-268-4/?rtype=10 with pushrods of course, is this a good deal/set? I'm not looking for a huge build up, I just want to beat ricers at lights since this is my DD.
Then I was thinking http://www.summitracing.com/parts/EDL-3704/ with all the TBI goodness.
For heads I was just going to port and polish my stock heads, is this worth it? I don't want to spend stupid amounts on heads.
I was going to get a chip from TBIchips and the high pressure fuel pump/regulator. Will all this work? What am I missing because I'm sure I am. Also BIGGGG noob here can I install these and drive my truck? I'm okay if it isn't tuned perfectly as long as it will drive. The chip will come after everythings in unless I can't drive it.
