Does this link to the 1991 emissions manual work?
http://www.mediafire.com/file/ki97h...Fuel_and_Emissions_Including_Driveability.pdf
PDF page 53, figure 3-12 at least until it gets into the tech1 stuff. You can ensure there are no codes (other than 12) with just a paperclip jumpering the ALDL as mentioned. From my experience if something is wrong, the check engine light will not respond properly when you turn the key on but do not try to start the engine. Not saying that is a given, but just what I've experienced. When something is wrong, the light often gives an indication in one form or another. In my case, the light won't blink when the key is turned to run, before staying on steady.
Then you can jump to page 72. Most people apparently hate actually following the flow charts (myself included) and if you have known good spare parts, it is sometimes faster to swap them than it is to test, but the charts generally make sense to follow. Kind of hard without a scantool however.
Where do you live?
Where do you live?
