GMCJason
I need some help getting my Suburban to pass emissions. I took it in the other day and it failed; CO and Hydrocarbons way to high at both idle and 2500 rpm. I figured it may not pass because it just smelled rich. I was right.
We took it camping over the weekend and it just didn't sound right at idle or at a higher rpm so I started digging around. I found one of the plug wires laying on the exhaust manifold and the insulation had been burned through and you could see the wires. Moving it and wrapping the exposed area in electrical tape seemed to help, at least as a temporary patch until I got home. When I got home I replaced all the plug wires and took it in again - failed again with the same problem.
Now, I had problems last inspection time (2 years ago) and at that time I replaced the O2 sensor, all the plugs, and put in a new air filter. Before I tested it the second time I changed the oil and got it nice and hot and it passed. All that is 2 years old but it only has about 4000-4500 miles on them so I wouldn't call them old.
What else should I do? The check engine light hasn't come on so I assume there are no codes but I haven't checked. If I were to take it to a shop what would they do besides tune it up? Since the CO and HCs are so high it's obviously not completing combusting the fuel but I'm not sure what else to do. I hate just replacing parts because they might be bad. Is there a way to tell if it might pass without actually testing it? How do I know if it's fixed without forking over another $25?
For the record the engine is supposed to have about 40-50k on it and when it passed 2 years ago it seemed to do so with flying colors, not squeaking by. The engine is, as far as I know, a stock replacement.
Thanks for any assistance.
Jason
Jason
