TBI 350 engine surging problem
tomtom
Registered Member
Louisville, KY
My 89 K5 sometimes when I first start it will surge, it will surge so bad it will quit. I can shut off the engine and restart and it runs fine. Anyone had this issue before that could shed some light on the problem would be appreciated.
Post this in the TBI section! :)
I have a similar issue but I have headers and a non-heated O2 sensor which I believe is to blame but don't know for sure.
I really don't think the headers are your problem, I dunno, just from personal experience, I have long tube headers on mine, back when it ran, it started and ran fine even with the o2 sensor unhooked.
Drove it to Indiana and had a different issue at times, accidentally pulled on the o2 sensor wire, unhooking it. I continued to drive it, yes the CEL was on, but nothing ill about the way it ran, maybe used a bit more gas, that's about it.
Possible Idle air control valve. I had a TBI surge on startup die, restart and that was the culprit. Does the CEL come on when the surge occurs? I cant remember off the top of my head what the values are but you can check the electrical signal at the Idle air valve and see if its responding correctly.
