I have a 1990 K5 blazer with the TBI 350/700R with 174k miles. Recently the car started surging/running rough at low RPM to the point that I stopped using overdrive. I also noticed it being rough just idling forward. I had been getting a code since I had redid the head gaskets intermittently and finally decided to check on it. It turned out I never reinstalled the vacuum line to the EGR valve. Upon reinstallation it seemed to fix everything. Then the motor started loping like it had a big cam with a low idle while I was coasting to a stop. I noticed it doing this as lightly drove forward in a parking lot as well. It never does this just at idle, only while moving. It's also fairly inconsistant as I can't make it do it everytime. I suspect it has something to do with the air idle control valve. I took it off but it doesn't look particularly dirty. I'm not sure how to clean/test it and I don't want to just throw $50 at a new one until further diagnosis... Also I has since started running rough at low RPM again and it doesn't sound very healthy...
Well I just reinstalled the IAC and now it won't even idle without a little throttle and sometimes it will idle but BARELY I mean I couldn't even hear it at first. It does the loping thing even just sitting now but sometimes it's just smooth. On the drive home it felt like power was starting to cut out... It did throw a code since I reinstalled the IAC; 33 - MAP (manifold absolute pressure) sensor circuit high (low vacuum)
