- Joined
- Mar 3, 2000
- Posts
- 9,123
- Reaction score
- 7,076
I just swapped tranny (350 to 400) switched from NP 205 to ORD 203/205 doubler, and installed Winters / Art Carr floor shifter.
The exhaust is off and I am running rams horn manifolds. Oxy sensor was on old exhaust, so right now Oxy sensor is there but not hooked up to anything.
Turns over fine but no start. If I pour fuel in it will fire up but since I am alone I can't pour fuel and work the ignition and gas at the same time so don't know if it would stay running if I had 3 long arms and could do all that.
Questions:
1. With key on should I be able to move throttle linkage and see fuel shoot out?
This is a stock TBI 350 from a 93 suburban, it has been in the vehicle for about 5 years with no issues.
2. How to test fuel pump to see if pumping fuel? I can hear it turn on and kick off as usual when you turn key on. It is a frame mounted fuel pump as I am still working off the original 1970 fuel tank that has been cleaned and re-conditioned when I put the motor in years ago.
3. I did hook up ground to frame. I went from the fuel pump boss to the frame. I tried it both with it hooked up and without first.
Just thought I would ask some questions before I start throwing parts at it. Thanks.
Questions:
that mounted the doubler crossmember pinched the wire from the fuel pump and that blew the fuse.
