redbird00
ok, so no ses light period, so couldn't pull codes. where should the light be? on the fuel level side by the parking brake light? or under the speedo by the 4wd light? i guess i need to pull the gauges and see whats up, which is fine to get the wiring for the temp sensor.
also, there are 2 coolant temp locations? the one on top of the motor where the coolant comes out and to the radiator? there's a wire connector there but all looks good? could the sender be bad?
and a second on the drivers side between the 1 and 3 cylinders? not sure what that broken wire goes to, connected the two but didn't do anything.
and anybody know what this wire connector goes to? passenger side valve cover.
