TBI 454 pretty much stock rebuild. The motor runs pretty good cold with just a random noticeable miss at idle which seems to go away as it warms up ~2-3 minutes. Throttle response is good and everything seems fine until the motor gets up to ~200* then it develops a decent miss which is considerably worse under a load.
Towed with it a couple weeks ago and it seems fine running down the road, but if i stop getting going again the motor misses horribly and has very little power. How bad it runs seems to be directly proportional to how much of a load is on it. Normal driving it misses, but if you apply enough throttle it still moves pretty good.
I had this problem once with a code 45. I ruled out the MAP and changed the cap plug and wires. I also fixed a broken fresh air vent line on the driver side valve cover. Seemed to run fine for a long time, but the problem is reappearing.
