xCaliK5x
I searched but couldn't find a specific. I disconnected the battery to clear my codes, how long does it take the computer to relearn the parameters properly for mixture, timing, etc? All of the equipment on the truck is stock and fully functional. I am unfamiliar with domestic stuff, most of the cars I work on, later model BMW's will set in about 20 miles. I put it on the smog machine tonight after I reset it and had driven around the block. My emissions were great at idle, way worse then it was before I fixed my exhaust leak and changed the 02 when tested under load at 15 and 25 MPH. That is why I was wondering about the adaptation/learning curve of the TBI ECU. Thanks in advance.
The state of Kalifornia really wants these things off the road. Cash for clunkers didn't get it, but CARB tightening their standards every year on these things may catch up to it eventually. I mean every thing is there, and functioning as it was when it was new. How can you ask the thing to run CLEANER then when it was new? We need to push for the reinstating of the 25 year roll off of cars like this. It may see 100 miles of use a month, its not a threat to Bambi, and nature, er, at least smog wise!
