TBI cam help.
chevyjeff
WYLIE TEXAS
Has anyone had any good or bad experience with this cam. Comp Cam pt# 12-249-4. Its described as great in stock throttle body or crossfire. I am planning on running it in my 350 build up using 9.3 compression, edelbrock tbi perfomer intake manifold, stock exhaust manifolds and stock computer. It will be used in my full size blazer so low end and torque is all I am after with this combo.
Here are the cam specs as listed on the spec sheet
Part Number 12-249-4
Engine 1955-1998 Chevrolet
262ci-400ci
8cyl.
Grind Number CS XE249H-12
Description
________________________________________
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.434 0.444
Duration At 0.006 Tappet Lift 249 260
Valve Timing At 0.006
Open Close
Intake 16 52
Exhaust 66 14
These Specs Are For The Cam Installed At 108 Intake CL
Intake Exhaust
Duration At 0.05 206 212
Lobe Lift 0.289 0.296
Lobe Separation 112
thats the same cam im running, I like it over stock. youll notice the differnce when it is fully broken in
/forums/images/graemlins/thumb.gif did you modify your throttle body and or the computer to get it to run correctly?
i didnt change anything since they said i didnt have to, but i figure if you do a custom chip, and a larger thortal body you would be able to take the cam to its full potential
Cool! thats what I needed to hear. I will likely mod the tbi at later date but sure dont want to swap cams after the motor is in and have a cluster on my hands!
If I go with the same cam on my 87 with vortec heads and edelbrock performer intake, headers and the Turbo City upgrade for the Vortec heads how much hp and torque would I be putting out or would it be worth it.
the best thing to do is call comp cam or any cam manufactur you prefer and tell a tech what you have and they will set you up the guys at comp cams were friendly and answerd all my questions
