Selling all the stuff I have to make your own ECM chips. I have a UV chip eraser for the older non-flash chips, a Pocket Programmer III USB this is the chip "burner" or writer and a Moates USB ALDL connector to hook a laptop to your auto. The software can be downloaded to make the modification to the chips, I used Tuner Pro. Also included is a custom "quick change" 7747 ECM this has a lever chip connector to quickly swap chips without having to fiddle around with the chip carrier until you get the final results then just swap in your regular ECM. I also have a handful of 7747 chips that are blank.
In the one picture you can see the ZIF socket installed in the ECM. This makes for fast and easy chip changes. The "black box" on the right in the top picture is the UV eraser for the older chips with the "window" on top.
Asking $400.00 plus shipping
