kwissman
I have been getting an intermittent Code 44 Lean Exhaust on my 91. It seems to come on when it gets up to temp and will go on and off with varying times that it is on. The engine is stock with the exception of long tube headers. I put in a heated 3 wire O2 sensor last year when I did the headers. The light came on right after filling up with gas and the Idle was erratic and very rich.
So far I have done the following things with no luck:
1. Replaced fuel pump with one for a 96 vortec 350. I was planning to replace it since I did not trust it. No Change
2. Replaced Fuel Pressure regulator. Checked and adjusted fuel pressure. I currently have it set to about 15psi and it runs rich enough that I get black smoke at idle. I just did this last weekend.
3. Checked for Vacuum leaks with carb spray. No leaks found.
4. Checked EGR with a vacuum pump. It opens and closes. Not sure of what else to check on the EGR.
5. Changed out fuel filter. It had maybe 500 miles on it and when I dumped it out it looked like the gas was darker than normal. No change.
6. Checked wiring on the O2 sensor and could not find anyting wrong. It is getting the 12v. I don't have a way to monitor the O2 voltage while it is running.
7. Checked Injector spray pattern and it looks good at idle and off idle.
8. I tried the Affordable Fuel Inj troubleshooting and after I turn it off and restart it the light is not on. The engine goes into closed loop, so it says the problem is intermittent.
9. I have run the gas low and added Heet to remove water and FI cleaner and it still is happening. Filled up last weekend
Questions
1. Can an O2 sensor just intermittently go in and out of band and still work sometimes?
2. This started about 5 minutes after I filled up with gas before a trip. Could I have water in my gas causing this problem?
3. What other tests can I do on the EGR to see if that is possibly causing my problem?
Any other ideas other than replacing the basically new NTK O2 sensor.
Kent
Questions
Kent
