skyhigh4by
My truck is an 82 with dual tanks originally carbed but now has an 87 tbi with holley TB and walbro pump.
I can't get my fuel pressure below 15 PSI. I figured out today that the problem is the return line. I took it off and ran return straight in to a jerry can with 3/8" hose and I was able to adjust pressure low enough that engine wouldn't even run (2-4psi)
So I crawled underneath and started to look at the steel return line and the selector valve(which doesn't work) and realized that the stock steel line is TINY (1/4"???) Then I decided to look up the part #s for the selector valves and from 82-87 the aftermarket uses the same # but GM part # differs. Is there a difference between the 82 valve and the 87 valve? Do I need one for an 87? Also is that tiny return line whats causing my problems? Too small to return the fuel my pump is putting out. The pump is 43 psi 155 L/hr and is mounted on the inner wheel well.
I want to change out my selector valve anyways because my fuel gauge isn't working and it would be nice to have use of both tanks.
