bassin4507
Registered Member
Your best bet would be to either get a set of flow matched injectors or get your current ones cleaned. The guy at turbo city told me that with the 68 lb/hr injectors you would be creating more problems with a stock motor. If you changed heads and increased the compression ratio the 68 lb/hr might be better for you. Give turbo city a call and tell him want you want to do, and call up some cam manufactures and get their advice. On my 91 I have the bored out throttle body, flow matched injectors, vacuum fuel pressure regulator, shorty headers, and a 3'' gibson exhaust. I orginaly had a Jet fuel pressure regulator, but ditched it in favor of the vacuum one. I wouldn't recommend the Jet one, couldn't get my motor to run right with it and it's a pain to adjust. I would also get a fuel pressure gauge from here CFM tech
