And not plastic oring. They have little rubber o-rings. If you pull the filter, they are the same type of fittings. You can get AN adapter for those fittings as well.
Ok cool so the frame connections are just the opposite of the throttle body.
16mm and 14mm x 1.5 with the o ring female fittings. Yeah I'm trying to run AN braided lines from the frame to the motor. I kinked a hard line behind the TB portpr bad.
