jteck10
Ok so I have to twist both at the same time to fit gears into TDC, got itYes it has to pointing to #1 tower on the cap.
Know that as you 1st engage the gear it rotate clockwise, and must engage the oil pump drive at same time. Bit of tongue stuck up nose with correct fingers crossed task.
1 tooth off in either direction is enough to make run poorly or not at all.
Try again, this is something many seasoned mechanics have to twice every now and then.
Where is the oil pump drive located?
