kennedy6949
Registered Member
This is my first post, although I have been lurking a while. This is the first question out of about a thousand that I couldn't find with the search.
I have a 1987 Sub 3/4t 4x4 with the TBI 350. When I purchased it, it took a little to long to crank, so I replaced the fuel pump, strainer, and for good measure the relay, with a new Airtex unit. This fixed the problem and it ran pretty well.
The last owner broke the hard line to the TB and replaced it with hose. I went ahead and put in a fuel pressure gauge with new hose and fittings. I also went ahead and rebuilt the TB, including making the regulator adjustable.
Now for the problem. After starting it cold, the pressure comes up to about 13.5 lbs, which is good, but drops slowly and steadily, until it warms up and hovers around 8.5-9lbs. When I adjust the regulator, the cold pressure moves, but always ends up at the same 8.5-9lbs. If I let it cool down, it will come up to 11lbs or so then drops back down. I can't figure it out and really don't want to drop the tank and change pumps, unless I have to.
If anybody has any ideas, please let me know, it's driving me crazy. I don't know if the pump is weak, its electrical, or heat related.
Thanks in advance.
Thanks in advance.
