I just got my truck running this last weekend, everything was running great smooth Idle, started right up, great throttle response. I noticed i had no gauges so I just through on a set of mechanical gauges I had to verify I had oil pressure before I got to into it. I had good pressure, temp was holding, and my Alternator was putting out good voltage. Its a 350 with edelbrock intake, original heads ported to match intake, and headers, hooker long tubes, 3 wire o2 sensor. I ran it up the road about 5 miles, and back, let it idle for 5 to 10 min to see if I was leaking anything turned around to park it and work on it tomorrow when it died and wouldn't start. It ran really great on the road, had plenty of power, exactly what I expected. I tried cranking it again, and it looked like one injector was dumping way, way to much fuel. This is where I think the problem is, because I can turn the fuel pump off and she will fire in about 2 cranks and then die when it runs out of fuel. The second I turn the pump on it will not fire. I think I may have a stuck injector because the left injector after 3 cranks had a puddle of gas stuck on the butterfly, but the right had just a light coating. Do you think that is my problem? or is it an O2 sensor not reporting correctly causing a lean condition? I guess I should run the codes tomorrow see what they are. Just trying to get a game plan together!
Thanks for all the help guys, I'll keep ya updated.
