Uh i no you are the one making the changes but when YOU are off the computer has to learn the correct fuel curve so it does have to do with learning. There is no way to tell the air fuel ratio with nothing but the software and a stock system... at least i haven't seen one.
Everything will be clear if you do some research.
My last post on this one.
http://winaldl.joby.se/
