TBI hardline to AN-6 fitting adaptor
metalneverdies
oklahoma
Hey guys,
I am looking for an AN-6 fitting that will mate up with the factory steel hardline on the frame rail. The factory had the braided stainless steel hoses. Due to my LSx swap I need to run some new fuel lines to the motor.
I believe the one hose is 3/8" NPT and the other is metric and my local hardware store had nothing that would screw into the connector to verify its size.
Do any of you guys have that info or the part numbers for the fittings?
Plan is to run every thing factory up to the portion of the fuel lines where it goes to braided stainless. At the connections near the passengers foot area I will run the AN-6 adaptors and run some stainless steel braided fuel line up the motor and connect to the factory LSx quick connects.
Thanks!
Not sure if these are the same as what you will need but these are the ones need to hook up at the sending uint.
EAR-9894DBHERL
EAR-9894DBJERL
They screw on to the fittings on the sending unit so you can use AN6
Click image for larger version
EAR-9894DBHERL
EAR-9894DBJERL
After some research and help I was planning to order the fittings you listed and see if they fit. I will report back what I find.
If you have any doubt call summit first, they will be able to tell you just which ones you need.
