Tattoojack
Registered Member
So I have a 1973 K5 blazer with the 350ci, TH350 trans and np203 t-case. Previous owner put a throttle buddy on it. Injectors lost 12v somehow and were only getting 8v. I ran a wire to the 2 positive wires going to the injectors thru a toggle switch and to the battery direct. I flip the switch, injectors get 12v, blazer starts. While running, I can shut the switch off and stays running fine. Problem is, won’t start unless I flip the switch. Will this harm any of the system they installed? ECU, ECM, other electronics?
