So i pulled it all apart and it seems that everything is indeed correctly installed and seated (at least by what i can tell) I installed the smaller spring and reassembled to test it and the PSI is now closer to 17 psi but, that is with the smaller spring backed all the way out!
At this point things are really starting not to make scene.
Are the diaphragms specific for application sort of?
Could it be that when i replaced the diaphragm the new one is stiffer???
I did notice it was not the same material but rubber but all the new ones are rubber
