Hi,
I have bought a 1988 Blazer that had a 454 engine swapped instead of the original 350 and it has a TBI, My problem is that the car runs way too rich and by reading some related post and some YouTube videos i have tested the common causes for a rich idle which are:
MAP Sensor 5 to 0.5
TPS Sensor .5 to 5
and they all had good signals and were in range from what i have been reading, I found out that i don't have an O2 sensor and I just purchased OBD1 scanner which will arrive in mid March since i don't live in the US, would be great if i can get some pointers on how to fix this problem, Plus I know it has this cam on it cca-k11-601-8 from comp cams.
MAP Sensor 5 to 0.5
TPS Sensor .5 to 5
