77crewcab
I am buying a 77 C10 SWB and want to swap in a 350TBI/700 combo but have a few questions on some small details ya'll might be able to help with.
1. For those of you that have done the TBI swap in an older truck, how did you mount the ECM? The older trucks don't have the brackets spot welded on so how do you mount it? Transfer the brackets or some other method?
2. This truck has dual saddle tanks. Can I use the TBI sending units from a burb/blazer tank? I would probably only use 1 tank until finding all the correct lines for the dual tanks and TBI tanks if need be.
3. The bed has been swapped for a newer one with the gas fill doors rather than the cap in the side of the bed. But they didn't swap the filler necks, so the origional cap in side of bed filler necks are just tucked inside the doors. Can I use the filler neck from a burb to fix this or is it too different from a pickup style?
4. How difficult would it be to put in a burb or blazer tank under the bed instead of the saddle tanks?
5. My donor for the engine/trans will be my 90 burb, so it has the electric speedo. Is there any reason to switch to a cable speedo? I have both style harnesses but kind plan on just taking the entire under dash harness from the 90 and swapping it to the 77. Any issues with that idea?
Any other issues I should be aware of?
Thanks for the help!
) is about the best you can hope to find.
