TBI issues dies at idle (solved)
formercruiserhead
Granger Indiana
On the way home started missing bad, died on the road several times but kept it in gear and made it home. Check engine light was flashing on and off all the way home. Codes 32, 42 and 43. Cleared codes, fired up and would idle for a minute or two then stumble and die. Code read 42 only now. Did diagnose and per flow chart was bad ICM or open in wire. Replaced ICM and started and idled fine for a few minutes. Would falter a couple of times then just die. No codes at all.
Looking for suggestions or another flow chart somewhere?
After more testing found distributor worn, replaced. Still had intermittant stalling and injectors would keep firing after stall. Very weird and random issues. Idle would be different everytime I started ect. Anyway was able to swap out with another ECM and fixed the problem.
