TBI motor. Autolite 25's or 26's?
Which plugs, 25's or 26's?
  • Total voters
    12
y5mgisi
1 ton status
Portland Oregon
Hey fellas. I need a new set of plugs in my suburban. Its a 90 TBI 350. In my older trucks i have always ran autolite 26's and like them. The recommended plug for this motor is a 25. Is there a reason why i should/shouldn't run the 26's? A hotter plug seems like a better idea to me. Any input? Also, i would be open to suggestions for other plugs but i hear that alot of the fancy plugs like platinums and so on end up not working so good in our older trucks.
this will be interesting:thinking: cause I was thinking of asking a similar question about what plugs are preffered over all.
I always use 25's, unless I have a high mileage, oil burnin' motor, then 26's to keep the oil carbon build up down a little longer. Just my $00.02
nothing wrong with certain types of AC Delco platinums, I'm running the Platinum professional series in my Burb and it ran great with them, they are an exposed type tip, similar to the standard electrode tipped ones.
I don't run those 2/4 tipped ones, and stay extremely far away from the Bosch junk platinums, I personally tried them twice, because they were cheap, burnt through them in like 3 months.
But either way, just curious as to why you are stuck on the Autolites?
autozone sells delcos.:waytogo:
could always go with champion....
:haha::haha::haha::haha:
NGK's and Autolites are decent, but I'll take AC Delco's anyday... Champions.... well, you know...
The more things change, the more they stay the same, I guess.
Way back when, Platinums were just coming out, and they were a disaster. In the then new engines, they were great.
Good firing, last forever.
But, in almost every case, when put into an older car, you got a skip or misfire. Personally, I never totally understood why, Platinum has less electrical conductivity than copper, but at those voltages, you would not think it would make that much difference.
Part of the problem, was that most of them were Bosch back then. But some of the other names came out with them and they caused misfires too.
I was hanging out on the Cserve Auto forum, which was fantastic. Imagine this place with actual factory engineers and techs dropping by to answer questions.
There were some reoccurring questions that got asked so often, that we created what you would now call a sticky that we could just point the person to.
The most common one was timing belts and water pumps.
Folks would post about how their mechanic was trying to cheat them by telling them that they needed to change the timing belt even though it was not worn out.
Or, they were trying to pad their bill by suggesting a new water pump at the same time.
So, we got tired of explaining about interference engines and how all the labor was already done so go ahead and drop in a new water pump now instead of later.
We never created one about platinum plugs, but one night late, I was about to got to bed and someone posted that their car had been running OK, but they changed the plugs and wires and now it was skipping.
They did not say what they put in, but I just posted "Take out those Platinum plugs and put in the regular ones and it will be fine" and signed off.
Next day there was a shocked reply wanting to know how I knew he had put in platinums, and that when he changed them it ran fine.
Since then, I have read here where some folks have used them with no apparent problems.
I suspect some of the trouble has been related to brands, and some of the ones here might have upgraded spark systems.
And maybe some engines just like them. I know I will not put them in my older truck, but will put them in my newer car that came with them.
exactly.... we run em in a ton of the newer 4 stroke OB's, and they do great.... SB and BB chevy Merc IB? not a chance in he!!.... i've had soooooo many owner installed iridium blah, blah, blah plugs that ran like chit... a fresh set of MR43T's or LTS's, and they run like a champ.... Merc has a couple NGK recommendations, but 95% of the V8 models call for AC's.... I'm good with that.... believe me, if anyones gonna see a quality difference in AC, it'll be me... and I'll be b*tchin... I probably do well over 100 V8 plug jobs a year...
25 is fine unless you have oil issues like someone else said. Vatozone gave me 25s last time. Did very well. Lasted 2 years in a oil burner that needs valve seals.
My opinion: run what is spec'd, and run ac delcos.
Other brands might be ok, but delcos have a solid record. Mine have over 30k on them and look great, gap had barely opened up last I checked them, and HEI has no problem jumping a large (.080) gap.
If there arent engine mods requiring changes to heat range, zero reason to change. Its *possible* hotter plugs could induce some knock that the sensor would hear, and retard timing. You would never know without monitoring the knock signal. NGK agrees https://www.ngk.com/learning-center/article/207/i-have-slightly-modified-my-motor---do-i-need
Autolite 26's are equivalent to AC R45TS or R46TS plugs,the 25's aren't that much colder really,I ran both in my old small blocks with carbs..
They went to CR43TS plugs after EFI came about,probably due to the leaner mixtures ..
Ran NGKs in my old evo Harley. Only plug it really liked after I "upgraded" it. I run delcos in my chebbys.
