I searched, found an exact problem, but no solution was posted...
So a couple years ago my suburban would not start, no fuel would spray while cranking. With starting fluid, it would start and run no problem. It has never shut off/stumbled after I started it.
As a workaround, I wired a pushbutton to the injector wire. When I turn the ignition on, I tap the button to send a ground pulse to an injector, crank it, then it starts and runs! (been doing this for a couple years now).
I kinda like the "problem" since it adds a bit of extra security, but I would like to know the problem just in case another problem develops from it later. Any ideas?
BTW, the previous owner (former brother in law) had to run a separate "hot on run" wire to the fuel pump since the factory one quit working. Could this be related to my current issue?
If it matters, I get the occasional CEL (unsure of code), but ONLY when running on the freeway for 10+ minutes. Upon stopping and restarting, the light goes away. No noticeable changes in drivability occur when the CEL turns on.
