I just got a 84 Silverado K5 4x4 Blazer with a 6" lift, like new 35" Pro Comp XTerrain tires on 3/4 ton axles, TBI 350 motor, Turbo 350, and a NP 203 transfer case.
The problem is the motor doesn't produce as much hp and torque like my previous Chevys - 87 K20 4x4 with a TBI 350 and 700r4, or my 89 K5 4x4 Blazer with a TBI 350 and 700r4. It has the TBI factory wiring transplanted into the 84 with the VSS and Park/Neutral switch installed as well.
I'm trading my 92 Pontiac Trans Am Firebird for a 86 Silverado K5 4x4 Blazer this coming weekend that has a 6" spring lift, 37" Wrangler AT military tires, 3/4 ton axles with lockers , 91 TBI motor that has an Edelbrock cam, intake, and carb, 700r4 trans, NP 208 trans case.
I'm debating on which Blazer to make my wheeling rig, the 84 or the 86 K5? The body of the 84 is a little bit better then the 86.
To me it always seemed like a carbed motor produced better hp and torque vs the TBI motors I had, but the TBI motor has the better drivability aspect for off road wheeling.
What are your opinions on which Blazer would you make your wheelin' rig?
Thanks.
Thanks.
