BadDog said:Are you in a position to test this back to back with no other changes, not even fuel pressure? I would be interested to know if it makes a difference. Especially if you have access to a dyno (I wish I did) so that we can get real numbers. It's so very easy to "feel" a difference when there is none, I think it's wired into our brains to justify work and/or money invested.![]()
From my reading and modest understanding of physics, I'm betting it makes little or no difference to low rpm and tip-in performance. It might even hurt due to air column dynamics. I have to believe they put that there for a reason, and my best guess is that is improves low rpm drivability at the expense of high rpm (which is typical of many of the related systems) and why the 3rd gen guys do it to help their quarter mile times. I’m only mentioning this again since that is counter productive to what most of us want in a 4x4, while being bang on for the “hot rod” types, so their reports of improvement should be taken with a grain of salt…
Oh well, I've got nothing to offer but opinions, in many cases based on reading opinions of others, so I'll move along now...Good luck and I hope it works well for you, but as I mentioned earlier, I'm getting ever closer to making the call to reinstall my stock TB. Hmm, one good thing about that, I'll at least have the chance to test it back to back while changing only one (well, roughly one) variable...
No, I don't have dyno access or even a flow bench. Wish like heck I did. I have to base my assumptions on numerous other published articles and threads. I think you summed it up nicely though. The only doubt I really have is the radius people are adding. From all I've read the high performance cars using varying forms of TBI are relying on a fluted shape of induction even when the injector is way down inside the assembly. 3rdgen guys are the exception and follow the school of thought that promotes a radius. Of course they all have the GM throttle body and high rpm improvement may be inherent in that particular design.
These are only my opinions, if you have a chance to make a comparison make sure to post your results. I'd be very interested to hear about it.
