I've been dealing with this issue for a few years now. It's getting to the point that I can't get very far down the road (14 miles today) without this problem showing up. I couldn't find anything helpful in a post search.
As I'm driving down the highway the engine suddenly loses power and starts popping out the exhaust. It will idle normally but start popping when the engine rpm increases. After limping along the shoulder with the engine close to idle rpm, it eventually clears up.
It's a 1987 K5, TBI 350, 700R4, 100,000 miles. I have changed the following parts chasing this problem:
distributor cap and rotor
spark plugs and wires
ignition control module
ignition coil
map sensor
egr
egr solenoid
spark controller
timing chain has about 20,000 miles on it.
the distributor is tightly clamped
It's almost as though I'm completely losing advance timing. But I'm not sure. I've never had a timing light on it when this problem comes up. I also notice the exhaust gets louder just before it loses power and starts popping. Any help is greatly appreciated. This is my primary transportation.
ignition coil
map sensor
egr
egr solenoid
spark controller
