hello,
I have a 1995 GMC C2500 Burb with a 7.4 TBI motor
it was running perfect until it died when I was driving it
tried to start it and it started again and drove it for a while then it died again
it started later after cranking it for a while but while I am holding the pedal @ around 2000 RPM it will die again
then it wouldn't start at all
I've noticed also when I put the key to start it the warning light in the dash are very dim and they will go off after a while
I've opened the Air cleaner and the injectors aren't pushing any fuel when I crank it
OK this is a sign of a defective ignition module
we've replaced the ignition module and viola it runs again
drove it for a while and it died again
later we replaced it with a new ignition module and it runs till it burn the module again
what should I be looking for ?
electrical short ? burnt wire ? loose ground ?
how can I see the trouble codes in the dash by clipping the ALDL connector? I believe this car is OBD I since it is 1995 model
we haven't touched or changed anything in the truck before this happens
your help is highly appreciated
Ahmed
Ahmed
