conoverbandit
Hey Y'all,
i'm trying to fix my 87 R-30 tow rig.It has 7.4 (454) gas engine in it, the problem I got is it "high idles" real bad, I've replaced to date : Temp sensor,fuel regulator, all new gaskets, new IAC (idle air control). Still dumping way to much fuel into motor. I was wondering if a TBI would work on this thing from a 88 model 5.7? I had a fella tell me that the computer is what talks to the injector and tells it what to do and how long, so the 5.7 set up should work. But i'm not sure, I did raid the injectors from the mother in laws 91 caprice 5.0. It would run, but surged really badly, couldn't drive it. So called local shop, tell them what it's doing, and they say IAC is bad....Changed it out but did'nt know you were supposed to "reset" it before you tried it. Needless to say it did'nt work right either, so put old injectors back in it and by then I had learned what the "resetting" was but with old injectors it's back to dumping fuel again.....Wondering of I should try and swap those injectors again, just to see if.......Need help here y'all /forums/images/graemlins/histerical.gif Thanks,
