Guys, I have. 91 5.7 TBI powered K5 that runs and drives fine.
Recently I had an auto start added. It works fine with 1 exception. On the first start of the day it will crank and not start. If you cycle the auto start again it fires off. What I suspect is the fuel system is loosing prime (I mean how long should it hold prime to begin with). In an effort to confirm the theory I cycled the key on and off cold. However unlike other FI trucks I did not hear the fuel pump come on. (If it did it was Damn quiet!). Needless to say cycling they key did not help it and you still had to auto start it twice to get it to fire.
Then it dawned on me. Does the oil pressure sender have to read OP before the fuel pump relay closes? Just wondering if that is the case then extending the crank time (on auto start) would solve my problem.
Thanks!
Thanks!
