Ok so the Burb didn't pass emissions and can rejet the carb to get it to work however was offered a good trade for a 454 TBI. I have a painless wire harness for a TBI, I have put a 350 TBI where a 4.3 TBI was so have some experience in what the swap needs.
However have some questions
Do you have to run a fuel return line from the TBI, if so does it have to go back to the tank ? Can it just go back to the inlet for the pressure line or the old vent line or something like that?
Is the E2000 the best pump to get ? as in cheapest easiest to find and replace etc.
(I will not run a in the tank pump, way to much of a hassel I am not dropping the tank to do this swap I will rejet it first)
Who makes a programable chip or something for a TBI, I have a lap top and want to play
My main reason for that is I have no idea what is done to my motor and I would like to be able to do some changes if I could.
