xenomarine
As the title says, I ran the truck out of fuel, refilled and it fired for a second or two and now won't fire. I've done some mild troubleshooting and it has spray at the injectors and spark though it looks weak, but that could be from the plug I was using as a tester being old, or a bad ground from resting on the vacuum booster(only place i could see the plug while cranking). The truck cranks fine, it isn't turning over slowly like advanced timing.
I have checked all the fuses and they all checked out good. Tried firing with the injectors unplugged in case they were stuck open or the CTS was bad causing a flood issue. Tried running on brake cleaner, nada.
I am not sure if it matters but I am running open shorty headers so the O2 sensor is probably getting exposed to cool fresh air. Anything I should be testing or checking first? I was going to take the ICM off and have it tested at Advance(scary, I know). I was also planning on replacing the coil and checking the cap and rotor next.
I'm just sick of working on the damn thing, I just swapped the transmission, rear springs and axle, and I have to do the front axle tonight to match ratios so I can plow for the storm coming tomorrow night.
The truck is an 87 v10/k10 chebby.
